Codystair
- Joined
- Oct 4, 2025
- Posts
- 42
- Reaction score
- 73
- Location
- Smithtown, New York
- Ram Year
- 2021
- Engine
- Hemi 5.7
Finally got around to beefing up the truck myself after years of pushing it off. All of this started with fixing a bad turn signal light and a ton of patience from the wife. First vehicle Ive bought new but after years of using my truck as a demolition debris hauler and loading her far far far beyond payload with sand, cement & tile + towing my tool trailer daily destroyed my already terrible stock shocks. Finally decided I’m done treating my truck like a ****box. All work done myself (I have trust issues and used to have a love for XJ’s lol)
‘21 Warlock 5.7L V8 ZF 8HP70 3.21
As of now she’s got:
- Cheapo Sailun Terramax RT 35” winter tires
- Upgraded all stock Halogen bulbs to LEDs (highs/lows, dome light, map light, footwell lights, vanity lights)
- Swapped to OEM Tow Mirrors
- Aftermarket rear bumper
- Added OEM Fog Lights & bezels
- Added OEM Tow hooks & bezels
- Added RAM emblem LED & amber grill DRLs
- Hitch mounted reverse/work pod lights (absolute godsend for hooking up my tool trailer)
- Truxedo tonneau cover
- Ceramic Tinted side & rear windows
- HDX running boards
- Sub amplifier & power cap
- Rockford Punch speakers
- Fox sub box with dual 12” Kicker subs
- Bed cargo/work lighting triggered by in bed switch
- Black LED third break light
- Auxbeam switch panel & fuse box
- Running board mounted LED courtesy/approach lights triggered by door open/unlock button
- LineX bedliner
- Bilstein 5100 Front Coilovers (2.1” Level)
- Bilstein B8 Rear Shocks & HD Lift Coils
- Airlift Loadlifter Ultimate 5000 Bags routed to license plate
- Alpharex LUXX Tail Lights
- Billet Tech Catch Can
- Moes Performance 87MM Ported Throttle Body
- K&N Breather Vent Filter (deleted intake-routed breather line)
- 6.4L Lower Airbox & Airduct upgrade
- Carven Progressive Exhaust w/ 5” Black ceramic exhaust tips
- Peddle Commander throttle controller
- Diablosport Pulsar set to Performance mode running 93. (Shouldve gotten an unlocked PCM & custom tune. I’m LOVING the Pulsar it’s so much fun but financially regret going this route as a custom tune would’ve done me better in the long run.)
- Caulk06’s ZF 8HP70 Transmission Thermostat Bypass Valve
- Legmaker Carbon Fiber intake “Mid” Tube
- Black lugs, stock 20” wheels
- BORA 1.5” hubcentric wheel spacers
- Suspension Maxx HD Extended Front Sway Bar end links
- Core 4x4 (Track) Rear Upper & Lower Control Arms, Track Bar & Rear Sway Bar End Links
- Roadmaster Heavy Duty Rear Anti-Sway Bar
- PPE Heavy Duty Aluminum Cast Transmission Pan
- Bulletproof 6” Drop Hitch
- Redline fluids throughout
Eyeballing the Powerstop Z36 full break kit & 6.4L intake manifold swap next. Possibly JBA UCAs but I don’t know that I need them just yet.
- LineX bedliner
