4wd light
  1. A
    2005 1500 4x4 Instrument Cluster Light Issue
    I have a 2005 ram 1500 5.7 hemi with a manual floor shifter for 4wheel drive. Ever since I have had it the 4WD light has never come on on the dashboard even when engaged. The 4WD works perfectly in every mode. I ran a C Code test on the dashboard and every light lit up EXCEPT for the SERV 4WD...
  2. M
    Wiring diagram 4WD
    hello everyone last year i posted about a problem with 4WD drive train. since then the car has being in and out of the garage but isn't fix. I have installed a new transfer case motor, a new select button and a new module to control the whole **** show. however after all of that they still...
  3. K
    2009 Dodge Ram 4WD Light
    Not trying to beat an old thread to death, but my issue is a little unique. My truck will engage into 4wd even though the light flashes. I can confirm this by when I turn sharp once it’s engaged. Sometimes the flashing 4wd light stays lit and the service 4wd light goes off and other time it does...
