Kenny Greene
Nocona
Not trying to beat an old thread to death, but my issue is a little unique. My truck will engage into 4wd even though the light flashes. I can confirm this by when I turn sharp once it’s engaged. Sometimes the flashing 4wd light stays lit and the service 4wd light goes off and other time it does not. The weird thing is though even when the 4wd light is solid and stay lit, under heavy acceleration and rough dirt roads it will cause it to start flashing again. What could be causing this?
huntergreen
Marine Corps Navy Badge
Have you checked for codes ?
K
Kenny Greene
Nocona
Yes, no codes ever come up with my code reader. Very aggravating, wish it would have a code, and it wound narrow the problem down. I’ve found that when I’m parked, and in neutral, my 4low will usually engage and stay lit, and I can switch to 4high, and it will stay lit, just will flash when I accelerate fast, or on a rough road
K
Kenny Greene
Nocona
May have found the problem, when I engage the 4wd and if the light keeps flashing, I can tap on the front axel disconnecter actuator and it will stay solid. Guess there is something wrong with the actuator. It does however still engage and lock the axel, but guess there is some kind of sensor or some kind of signal that it sends that it’s engaged, that it is not sending sometimes.
