alfa obd help
  1. jaxson112
    SiriusXM vanished from sources
    Hi all first post on the forums I have a very odd situation hopefully someone can help *paint the picture* I have a 2017 RAM 1500 tradesman that came with the Uconnect RA2 5” display. I’ve upgraded the entire interior as well as the head unit to the Uconnect 4C UAQ back in February. Everything...
  2. expressreg
    7 cluster upgrade
    I got the premium cluster upgrade for my 2017 ram express and this is my second one, but for both it was the same problem, when i tried correcting the miles on ALFAOBD it did its little procedure on the cluster but then it says “Procedure Failed” I wait a minute or so and them it says “Procedure...
  3. L
    Alfa OBD
    hey guys , just bought my ram 2014 sport utility 4x4 and i was told that the Alfaobd can also diagnose codes. is that true? i have a problem where i get messages only, but not check engine light ? Immediately I get Service Electronic Stability Control, Service Trailer Brake System and driving...
