bed lighting
  1. P
    Factory installed bed lights stopped working
    2019 1500 Laramie. Factory installed bed lights have stopped working. What I have done 1) Checked ground. Still connected but I need to pull it and clean it just in case. 2) pulled the driver light and checked voltage up to the switch. It's 12 volts. 3) tried checking switch for complete...
  2. J
    Bed lighting with third brake lights
    Hello yall Curious question. I tried wiring up some bed lights in my 2017 Laramie ed. Ram but to no avail. I’ve seen it done on you tube but I can’t get it to work. I tried tapping into the “brown/white” wire on the driver side door panel wiring harness with alligator clips. I am trying to run...
  3. gixxer
    How to Add Bed Lighting
    I bought the mic tuning kit from amazon. I bought the 2 piece kit. Came with a built in switch. Some of the wiring was really thin. Make sure to test the lighting first. You will need extra wire, sauder, shrink tubing, wiring loom, and duct/electrical tape. I first made sure I had room for the...
  4. OEDRO
    Led Bed Light & Strip Light Install Video for Dodge Ram
    The led strip light link: https://www.yitamotor.com/products/2x-pure-white-truck-bed-led-strip-light-for-chevy-silverado Led Strip Light for Dodge Ram The slim design makes it possible to place it anywhere you need lighting for greater safety and visibility. - Simple design exterior truck...
  5. OEDRO
    How to install LED Truck Bed Lights
    LED Truck Bed Strip Lights installation on Dodge Ram Here is the link of the led strip light in the video: 60" 2-Row LED Strip Light & Brake Reverse Signal for GMC RAM https://www.yitamotor.com/products/60-2-row-led-strip-light-brake-reverse-signal-for-gmc-ram $17.99 If you have any...
  6. D
    Program OEM bed lighting
    Is there any way to program your own OEM LED bed lighting for 2016 Dodge ram Laramie? All of the installation information I can find says you have to take it to the dealer for them to program it and it costs over a $100. I believe that to be a bit excessive and was wondering if there's any way...
  7. Boosted Motorsports
    How to INSTALL LED Bed Rail Lighting on Your Truck
    In this video I review how to install LED bed lighting on your truck! This is a step by step do it yourself video for those that want to tackle it on their own and shows what is involved. With some patience and some simple planning you can wire and rig up your truck to have led lights in the...
