2019 Ram 1500 Classic. My hvac blower has quit working. Ive replaced the blower, tried a second new blower, checked the underhood fuse, and swapped with a known good underhood relay and the blower will not run. The blower has the 3 wire connector plugged in to it. I have 12v on the 2 large wires...
Hey everybody newbie here.
Recently purchased a 2013 ram 1500 5.7 hemi. I am a new truck owner so I'm still figuring things out here.
Issue: I had a bad resistor. Installed a new one which is a perfect match to the previous. Before installing the new one I had low engagement from the blower...
Hello,
I have a 2014 1500 Sport with dual temp zone w/automatic HVAC controls. A couple years ago, I started having intermittent blower issues where sometimes it wouldn’t blow air. Found a burnt fuse and replaced it, fast forward a couple years the intermittent blower issues started again and...
Hey friends,
I wanted to ask if you can listen to this video of an up and close recording of the noise of my Blower motor and it's a little noisier than this but not by much when it's really cold in the interior. Maybe a cleaning or wd-40 to the motor shaft would help? I haven't removed it yet...
I'm at my wits end! My husband is military and TDY, my Dodge Durango started over heating so I'm driving his Ram. The fan has gone out in his truck that I'm driving and currently it's close to 100゚ here daily. I have to drive 45 minutes to work in that with no fan. I've replaced the resistor and...
