brake light
  1. T
    Right rear tail light issues
    I get a right rear turn signal not working message. The running light works but my turn signal and brake light do not work. Bulbs have been replaced. Struggling with finding the issue
  2. R
    Abs and brake light on
    Been fighting a demon on my 06 Cummins. Last fall had lights come on and off figured it was WSS. Had code checked for left front WSS circuit. Replaced with new sensor, after that light continuously was on. Had someone ohm out sensor everything checks out. Turns out to be a bad ground wire to...
  3. C
    2006 RAM 1500 CRUISE CONTROL, ABS LIGHT, BRAKE LIGHT
    So, this is related to a previous post for a problem I thought I had fixed. On my truck, the ABS light and brake light have always been on. I have always assumed this has something to do with the fact that the parking brake has been disconnected. Since I have owned the truck, the ABS has...
  4. USPatriot1776
    EVIC 7in Displaying Brake Light Out
    As stated in the title, my newly installed EVIC 7in Instrument Cluster in my 2016 1500 Tradesman is displaying I have a brake light out. I had read in the forums on here that it may be the third brake light but all is working in that department, there are no brake lights out on my truck yet I...
  5. R
    Front passenger turn signal comes on when braking.
    I have a 2012 Ram 1500 Laramie. I've had it for a few years. I recently noticed that when I hit the brakes the front passenger Amber turn light comes on solid with the brake lights. Then I noticed that the brake lights only come on when you have the key in the ignition. Has anyone had any issue...
  6. M
    LED upgrade complete, now throwing multiple errors
    So I upgraded all my Halogen bulbs on my '18 to LEDs the last two days. The Low Beam, High Beam, Front Turn Signals, Fog Lights, 3rd Brake Light and 3rd Brake Light Reverse lights, Taillight Reverse Lights, and Taillights. Everything up front works with no issues or errors. Everything in the...
  7. OEDRO
    Led Tail Light & Brake Light--High Quality,30%+ Off
    Yitamotor tail light: 100% Brand New & Never Used SAE/DOT Approved for street legal High Quality Grade ABS Plastic Lens Bolt-on style for installation, no modification is needed just plug and play All Free Shipping on yitamotor.com Shop Now! LED Tail Light for 1994-2001 Dodge RAM 1500...
  8. N
    Help please!
    Hey all! I really hope you can all help me out here. I am not much of a mechanic but I love my truck (2008 5.7L 1500 short Bed sport) I take good care of her to the best of my knowledge with oil changes and such, but I just had my ABS and brake light pop on simultaneously. The truck is acting...
