cam swap
  1. R
    6.4l cam in a 5.7l hemi dyno results
    2014 ram 1500 4x4 sport 5.7l hemi 8 speed truck 3.92 gears. Thought i'd make a little post about my personal experience for those who are trying to do what i did and just want a very straightforward answer. I read a lot of different forums during my planning stage and found a lot of conflicting...
  2. D
    Low idle oil pressure, after high volume pump install.
    2011 ram 1500 5.7 So I recently replaced my MDS lifters with non-MDS, replaced the oil pump with melling high volume oil pump, and installed an MMX NSR NTR camshaft. I also switched to a slighty thicker M1 5w-30 oil. (MDS delete purchased through moes performance.) Cold start: 80+ psi...
  3. R
    MMX Cam Swap - Tune Question
    Hi guys. I'm finished with my Cam swap after some lifter failure / cam failure on my 2013 Ram 1500 5.7 Hemi, and got everything back together. Ready to fire it up this weekend to test everything, but took a pause on the tuner side of things. I *think* i may have made a mistake with my order from...
  4. R
    Cylinder Head Alignment Issue - Cam Swap
    Hi Guys! I'm back with another question. A bunch of you have helped me in the beginning stages of my journey to a Cam/Lifter swap (see my last post ) Hemi Tick....but lifters look fine?? Long time coming on this, but I finally got the heads back from the local shop, and they look(ed) great! The...
  5. D
    NSR and No Phaser lock Cam 2011 5.7
    Doing a cam/lifter replacement on my 5.7 and want to know if anybody knows any camshafts that are no springs/no phaser limiter required. Also doing MDS delete and already have non mds lifters from comp cams (856Y-16) and new OEM pushrods. Been debating on cams for a few months but have ruled out...
  6. JCarr98Ram
    Need help choosing a Cam
    Hello, As the title reads need help choosing a cam. Currently, I noticed my tuck engine making a tick/tapping noise. After doing some research, everything came back as lifter failure. So I just thought if I have to replace the lifters might as well do the cam. I really don't understand how to...
  7. Gilberts Garage
    New Camshaft recommendation?
    Hey ya'll I'm new here, but have spent hours reading threads. I've been a GM/Chrysler tech for the last 13yrs so I have loads of experience in replacing parts. I've always replaced with oem parts, never installed a "performance" camshafts before. I have a failed lifter 4 weeks after buying my...
  8. ews25
    Anyone running Vararam-cam kit-shorties?
    New guy here. My 2011 Outdoorsman 5.7 is in the shop right now with a potential valvetrain failure. P0300 and #5 is zero compression, apparently. If that's the case, I'm contemplating MDS delete cam kit with shorty headers and a Vararam intake. Is anyone running that combination?
  9. OzzyH
    2011 Ram 1500 Sport 4x4 Cam Selection
    Hey everyone, I'm looking to upgrade my cam and upgrade to non mds to help alleviate a lifter issue. It's a daily driver so I don't need to much extra power but I would like to see some gains since I am going through the process already. I'm currently looking at Moe's Performance 5.7L VVT HPT...
  10. Manual Gen 4 Ram
    Accidentally misaligned cam and crank... Please help
    2014 Ram 1500 Sport 5.7L After replacing the camshaft and lifters my truck a few months ago I was going into limp mode, but only when the engine was cold. I checked the computer and it showed codes P0016, P000B and the timing changing between -13 and -16° off. The engine ran fine other than the...
  11. Colin15
    Cam swap tips
    Hey first post here. This isn't going to be very well written. I just did a cam swap on my 2015 ram and figured I'd post how I got the oil pickup tube bolt back in without dropping the pan. Hopefully this will save someone else a headache. I didn't take pictures or a video cause I didn't wanna...
mikeynosikey444
