camshaft sensor
  1. J
    2017 ram 1500 5.7 HEMI in limp mode
    I have a 2017 Dodge RAM 1500 with the 5.7 hemi. It started misfiring and throwing codes for cylinder 3. I replaced the coil pack and nothing changed. It was throwing codes for the camshaft sensor, I replaced it. Still ran like dog crap. Then it started to act like it wasn't hitting off of any...
  2. S
    03 PCM - 05 PCM swap trouble
    So I upgraded the camshaft in my engine and my tuner couldn’t work his magic on my 03 PCM, so I swapped it to an 05. because the engine started, I have good reason to believe that my wiring was on point. Took it back to the tuner and it was throwing a P0340 code - unable to find the camshaft...
  3. F
    New to Forum and Need Help with a 2000 1500 5.2L !!!!!
    Hello everyone. I am new to the forum and need some help troubleshooting my old 2000 Ram 1500 with a 5.2L engine. A little back story. This engine has nearly 270K miles on it and burns alittle oil but not much. It probably leaks more out of the rear main seal and valve covers than it...
  4. W
    P0016 Crank/Cam on a new rebuilt engine
    2011 Ram 5.7 engine scrubbed rollers and cam. Professional rebuild. New crankshaft and cam sensors, new phazers. On initial startup it ran like a new one. Ran to Operating temp then shutdown to cool and check all fluids and leak check, All perfect. Restart let run 20 minutes again then took...
