P0016 Crank/Cam on a new rebuilt engine
Wi Dave
Wisconsin
2011 Ram 5.7 engine scrubbed rollers and cam.
Professional rebuild. New crankshaft and cam sensors, new phazers.
On initial startup it ran like a new one. Ran to Operating temp then shutdown to cool and check all fluids and leak check, All perfect.
Restart let run 20 minutes again then took for a 30 mile drive. All perfect runs as it should no codes.
shuut down for 10 minutes then took out again and instant code p0016.
Wiring all looks good connectors all checked multiple times.
Pin tested terminals to see what is there, even though I do not yet know what it should be,
after code clear and battery disconnect
Cam sensor wire:
IGN off ALL terminals .5 Volt With mid terminal showing continuity to ground.
IGN on Outside terminals 5.5v center .5v
Crank sensor:
IGN off no voltage on any wire and center shows continuity to ground.
IGN on Outside 5v center .004v so zero.
Anyone know the proper voltage specs?
Any suggestions?
W
Wi Dave
Wisconsin
Perhaps I should have titled it "voltage readings needed"
I appreciate the bump.
5 minutes anyone could walk out to their truck and grab those readings....
Someone do an old guy a solid please...
Tach_tech
5.7L HEMI
Both cam/crank sensors should have the same voltage readings. There’s the 5V reference,ground and signal wire. Both the 5V reference and signal wires should have roughly 5V with key on. Measure continuity to ground of the middle pin.
P0016 is a misalignment code. Technically speaking a faulty cam/crank sensor usually won’t cause this code, it’s not even listed as a possibility for P0016.
Glowz
