climate control cluster
  1. UncleRooskie
    2014 Sport
    Ran into a problem with my climate control, only on drivers side. When adjusting my heat the temperature will drop from hi to low on its own, when I turn it back to high it will again drop to low. Sometimes the buttons won’t work and I have to adjust from the 8.4 screen only to have it drop to...
  2. L
    Climate Control Module
    I have a 2014 Ram 1500 5.7 L Hemi that I just purchased. When I drove off the lot I realized that I am unable to turn adjust anything with the AC/Heat. The dealership only says “as-is condition” and refuses to fix it. The A/C fan is blowing full tilt, which I thought could be a bad relay but...
