dome light
  1. C
    Overhead dome light switch not working
    I have a 2018 ram 3500 When I manually click the light itself to turn it on it won't work, but when I turn on all the interior lights with the dimmer switch they'll come on and will also cut off if I click the light while I have all the interior lights turned on using the dimmer switch. They...
  2. Kellce61
    Interior Lights work intermittently
    I have a 21 1500 Classic crew cab that I purchased used last summer and love it. Shortly after buying it we noticed the back cab light worked intermittently. Had it at the dealer for some maintenance and they said it had an LED build and shouldn't have, so they replaced with and incandescent...
  3. J
    Map & Dome Light on '15 Ram 3500
    This is an odd one that I cannot figure out. I have a 2015 Ram 3500 Tradesman. At night, when I unlock the truck or open any door the interior map and dome lights do not come on. It does not matter which direction I spin the wheel that is placed on the left side of the steering wheel. However...
  4. xxniko90xx
    Dome Lights/Horn/Steering controls stopped working HELP!
    I have a 2011 Dodge Ram 1500 4.7L. About two nights ago I opened my truck door and noticed that the dome lights did not turn on when the door opened. Once I started my truck up I then noticed that my Traction control or the Tow/haul button also did not do anything when pressed or light up at...
  5. OEDRO
    Interior LED Light Bulb Kit Package( 10+ pieces ) Up to $9.99
    One order and get all interior led light bulbs you need. Yitamotor Led light bulb package are much brighter than the stock yellowish tungsten lamps. Plug and play no special wiring or modifications required simply plug them in and use! All Free Shipping on yitamotor.com 5% Off Promo Code...
  6. M
    Slow battery drain and ticking from instrument panel
    2002 dodge ram 1500 5.9L. When I shut off the engine the instrument cluster remains engaged for a few seconds and the guages slowly fade down to off, the alarm light comes on and there is a faint ticking like a watch. dome light and door locks do not work unless the ignition is on as well. If...
