dual battery
  1. S
    Overland Project RAM 1500 2017 Longhorn (dual battery, water tank, air tank....)
    Good day, I would like to share my idea for a dual battery system. I have walded steel socket which is mounted directly on inner side of frame. My battery is too big to fit in underhood so i fit it under engine, it is close to star battery additionally it is nice for center of gravity. I am...
  2. A
    Dual battery for winch/other accessories
    Recently bought a 2016 Ram 2500 Laramie PW with an aftermarket winch. I've used the winch once, and after I was done using it, I couldn't retract the cable and my truck went into "power save mode". On the way home my truck died at a red light. Got it jump-started, started driving again, and it...
  3. L
    Dual Battery intake.
    I’m planning a dual battery setup to use with my ‘04 1500 for overlanding. I know a lot of people who have installed dual batteries use this CAI. I’d like to see different CAIs others have used. Ideally, I’d like the filters to be protected a little more. Thanks
  4. P
    dual battery and winch hookup
    don't know if this is the right section im looking at upgrading my power system in my truck my plan is to run a second battery in a bed box or make a custom storage area in the inside of the bed. plus i need a power hook up spot close to the tale gate of the truck for my trailers winch was...
