exhaust bolt
  1. H
    Exhaust hanger locations
    Recently purchased a 2004 Dodge Hemi 1500 5.7. Cat was already removed and muffler badly rusted out. I paid a guy as Im 32 hours away from home to do a muffler delete. Besides the worse welding job ever.Im a red seal welder( female) not a mechanic. I can give my opion on the weld. It was a...
  2. Steve-O
    Cracked Head from exhaust bolt repair!? HELP!
    Need advice fast! Brought my truck to a local shop to have the notorious broken exhaust bolt problem fixed. I guess there were a couple on the passenger side that were broken and one of the bolts gave them a hard time and somehow the head was supposedly cracked in the process or removing it! I...
  3. JCarr98Ram
    Torque Specs for exhaust manifold studs
    Does anyone know the torque specs for 1998 dodge ram 5.9L 360 magnum exhaust manifold studs/bolts?
  4. JCarr98Ram
    Studs for headers
    Hello, Wanted to see if some one can answer a question that I have. Currently, I am replacing my stock manifolds with JBA cat4ward headers. I am looking to buy some ARP studs for my 1998 dodge ram 1500 5.9L 360 engine,but they are giving me studs for a 5.9L cummins. Can I use the studs for the...
  5. S
    Need some advice / help. JBA headers
    Currently installing JBA ceramic shortys on my 2014 5.7 4x4. Passenger side is done dust need to re torque after a few heat cycles. Drivers side I’m having issues. 1. Best tool or way to tighten the 2 most bottom rear next to the starter header bolts. Using ARP 10 mill heads. I’ve used a...
  6. O
    Exhaust manifold hole pattern
    Does anyone have the hole pattern dimensions for the exhaust manifold bolts on a 2014 5.7 Hemi? I want to make a template for removing broken bolts. :)
  7. cancunlsp
    Header Bolts Dealer replacement procedure
    Hey guys, I have finally had the broken bolts on the Exhaust manifold. Went to the dealer to schedule warranty work and asked about what all they did as part of the procedure. They told me that the extract the bolts and just replace the broken bolt. They do not replace all the bolts and they do...
