cancunlsp
Hey guys, I have finally had the broken bolts on the Exhaust manifold. Went to the dealer to schedule warranty work and asked about what all they did as part of the procedure. They told me that the extract the bolts and just replace the broken bolt. They do not replace all the bolts and they do not check to see if the manifold is warped. Ive read a lot on here about this issue and it seems that the fix is either to switch to shorties or long tubes (prob will this summer) or the dealership fixes with the warped manifold on a belt sander or machine shop. Im curious as to why my dealership does not even check for warp much less fix it? Any techs on here that can give the actual procedure from Chrysler when doing this repair. Just seems to me that its being half way done.
