four wheel drive
  1. D
    Four wheel drive problems with
    06 ram 4wheel drive, the leakage com undone on my transver case back in the summer. Pin feel out didn’t worry about it till winter. When I hooked it all back up it was having a hard time shifting from first to second gear. Hard to run it clean out before it would shift than it shifted hard with...
  2. Mgreen529
    4WD engages, but front axle doesn't lock
    All, I have a 2007 1500 4.7 6 speed with a NV243 transfer case. Here is my problem, When the TC shifts I hear it go into 4WD, and I have verified this by trying to rotate the front drive shaft, it does not spin by hand when in 4wd. It does not matter if I shift to 4wd lock or 4wd low, the TC...
