front axle
  1. C
    Rattling noise from front axle
    I have a rattling sound (metal on metal) coming from my front axle. It feels like the noise is coming more from the driver side. I originally thought it was something with my brakes/rotors because I feel and hear it the most when braking, however I replaced both rotors and cleaned up all the...
  2. Justin G
    2007 1500 Front Axle disaster
    Was out last weekend and truck was sliding in the snow and got stuck. When we hooked tow rope around the front tow hooks I noticed the CV joint came apart. Upon further inspection I noticed the mount that holds the front axle housing up was sheared and broke. I can't find any built front end...
  3. Nathan Goehring
    The Dreaded Passenger Intermediate Dif Shaft
    Alright guys, I thought it would be helpful to start a thread on this nightmare of a problem. For that are unfamiliar with this problem, let me fill you in. On the 2012+ 4x4 Rams, the cv axle slips off the c-clip that holds it to the differential shaft. When this happens, there is last contact...
  4. C
    Front differential
    I have a 2003 Dodge Ram 1500 4x4 and my front axles have a lot of play moving but it’s the stub shaft bearings and seal that went out, and I was wondering what bearings and seal to order and how do I go about changing them
giantturkysub
