front end
  1. Eray
    Just found this site could use some help 2004 ram 4.7 rwd
    Had the truck for a year or 2 but front end started popping while turning the wheel been busy so put it off engine blew last year got it replaced and they ziptied everything instead of wiring correctly looked like a crackhead was under it but now i fixed all that but damn all bushings ball...
  2. J
    Do you need to keep front axle in to keep wheel bearing together?
    My wheel bearing fell apart the day after I took my front end apart, I had blown the front end and removed the guts including the axles. I re assembled the truck and the next day wheel bearing is gone, so I put a new bearing & hub assembly on and less than a km down the road same thing...
  3. T
    Mystery Front End Clunk...
    I'll try to give you the details without going crazy here... There is a TL;DR at the end. I know this is a novel at this point, but my stress and frustration are high enough that I'd rather y'all have all the details than be missing anything I didn't mention. For all I know, I'm overlooking...
  4. MN97SCB
    wonderful front u-joints....
    Have to wonder if it is just me or how common it is to have to replace the front u-joint every one to two years? Fortunate enough to have purchased the lifetime warrantied u-joints but it is still a pain to have to change them that often. Just wondering if there could be another problem I am not...
  5. Sho_Tyme671
    Aftermarket/Rebuilt CV joints
    GM Mopar fam. I am new to this forum so please bear with me. I was looking into rebuilding the front end of my '04 Ram 1500 4x4. I am starting with the CV axles due to boot failure of the drivers side and I know it's smart money to change both at the same time. I was looking on RockAuto and...
  6. Z
    Front suspension parts list w100
    I'm in the mechanical process of fixing up my 1988 w100. So far I've replaced the ujoints at the axles (and about to do the pinion side front/rear drive shaft ujoints), front brake lines/rotors/calipers, new drums/shoes, valve cover gaskets, plugs, battery, front/rear diff fluid, and gas tank...
  7. Larry Waters
    Strange clunking sound in the front end
    Strange clunking sound in the front and I have a sound it lightlyReverberates through the steering wheel. I notice it’s more prevalent obviously a bumpy road it almost sounds like a loose shock tower bolt. I took it to a non-ram shop they replace the tire rod ends wheel bearings steering bar...
KAKA
