heater vents
  1. Drewb0812
    Burning smell when using blower
    2023 Ram 1500 classic warlock v6. noticed a burning smell coming out of the blower vents when heat is turned on. The smell isn't as intense when I switch to floor and defrost but still noticeable. It's not a burning oil or electrical smell it just smells like something burnt. Truck only has 7K...
  2. S
    Possible Electrical issue with Climate control?
    Hi I finally broke down and started replacing parts in the climate control to pin point the source of this issue. I don't think its the blend doors (Possible denial to avoid full dash removal in middle of winter) but i'm starting to think electrical but not sure where to start. I have a 2003 Ram...
  3. Larry Waters
    6.7 oil adative ? Airflow out of the Dash Vents.?
    2012 6.7 diesel engine oil additive. does anyone have experience with Oil additives for cleaning the valves injectors etc. truck has 53,000 miles. My dashboard vents also don’t seem like you’re putting out as much air as they used to and sometimes I hear a whistling sound has anyone had...
Carbary
