ignition coils
  1. A
    Cylinder 1 misfiring — but only when I drive faster
    The car vibrates a bit more at idle (though maybe that’s just in my head because of anxiety). It also vibrates somewhat more when driving in reverse, but I haven’t driven the car for a long time. The car was sitting idle for about 7 months in around 110 degrees Fahrenheit weather. Acceleration...
  2. FORGEDRAM
    Failed Oil Filter Housing / Oil Cooler
    Alright guys, the dreadful day has come. My Oil Filter Housing/Oil Cooler has failed @ 105K miles. Here is a parts list I have whipped up. I plan on doing spark plugs, ignition coils, and valve cover gaskets in addition to upgrading to the Doorman Aluminum Filter housing. Are there any parts...
  3. H
    Irregular signal sent to cyl 1 ignition coil
    2010 ram 1500 ST 4x4 5.7 hemi with 195000 miles. Been having cylinder 1 misfire and hemi tick that has been progressing lately. Tried to fix the cyl1 misfire and have swapped spark plugs and coils but misfire continues. I was worried it could be a broken wire or bad connector so I used a timing...
  4. D
    04 RAM 5.7 REBUILD
    Hi everyone! My name is Devin and I have a 2004 ram 5.7. While I was riding down the road last October my main bearings went out and the crank seized on me. Completely shredded two piston heads, rods, everything, (got pictures if anyone wants to see) So I took the engine out, had the block...
  5. R
    Ignition coil secondary circuit help.
    Hey guys, I’ve got a 2015 ram 5.7 hemi Laramie longhorn I need help with, intermittently the truck would throw a misfire code for cylinder 8 (0308) now it’s a constant code followed by P2323 ignition coil H secondary circuit malfunction. Lemme tell y’all what I’ve done. Bought new coil and...
