lifter issue
  1. Q
    2022 Hemi 5.7L Lifter Tick
    All, I have a 2022 Big Horn, 5.7L with 53,200 miles. A week ago lifter on cylinders 5&7 where replaced by the powertrain warranty. One week after i started to hear that clicking noise again. I'm taking it back to the dealer again tomorrow. Any one had the same or similar issues you can provide...
  2. MarcoFuc
    Is it a lifter failure?
    So I have a tap/tick after camshaft and all lifters replacement along with a new oil pump “+10 psi above stock. And timing chain. But this tick only occurs when the oil temp is 180-200 degrees. And only at idle and soon as you add the slightest Rpm it disappears then returns once the rpm drops...
  3. S
    2020 RAM 2500 6.4L - Loud tick even after lifter replacement at 19K miles
    Hello RAM Forum, First off this is my first RAM purchase so I'm new to the RAM 6.4L hemi engine and all its glory and not so glorious issues. At around 7K miles my engine developed a loud ticking noise (see video). I took it to the dealer and they said it was "normal" ( I have this in writing...
  4. waqasrishi
    2012 RAM 1500 running really rough after sand dune drive
    Hi, I am new here and I own a RAM 1500 2012. I recently got it serviced and the truck was running really smooth after the oil and filter changes. I drove the truck in the sand dunes here in Qatar. If you have any experience driving in the dunes the ride is pretty rough at times specially...
