map light
  1. C
    Map Light Replacement
    I have been researching ways to change out the map light due to dimming a flickering, and kept seeing that you had to replace the entire console or cut off the plastic pegs. I found another way on my 2018 Ram 1500 Sport with the LEDs. If you stick a trim tool in between the black plastic and...
  2. J
    Map & Dome Light on '15 Ram 3500
    This is an odd one that I cannot figure out. I have a 2015 Ram 3500 Tradesman. At night, when I unlock the truck or open any door the interior map and dome lights do not come on. It does not matter which direction I spin the wheel that is placed on the left side of the steering wheel. However...
  3. Socalramfan
    Anybody know what this was intended for?
    Just completed a Full Console swap in my 2011 Quad Cab, love the look and storage options. Had to get a new center Radio bezel, (lucked out... got one of only two new ones in the US, but took a while to locate), upon receiving it I noticed on the bottom of the bezel there is what appears to be...
  4. OEDRO
    Interior LED Light Bulb Kit Package( 10+ pieces ) Up to $9.99
    One order and get all interior led light bulbs you need. Yitamotor Led light bulb package are much brighter than the stock yellowish tungsten lamps. Plug and play no special wiring or modifications required simply plug them in and use! All Free Shipping on yitamotor.com 5% Off Promo Code...
jimn
