mds lifters
  1. D
    Whats going on with this cylinder?
    Hi Guys, I noticed a loud knock on my engine. Immediately turned it off. It was coming from the even side numbered cylinders. I took vaulve cover off and cranked it to see whats up. Noticed that cylinder 4 stops moving after a few seconds. Please see videos. Please advise. Video Here.
  2. D
    Hemi 5.7 MDS Lifter Test.
    Let me give you some background. My truck is a 2009 1500 5.7. I blew the engine like 9 months ago [ceased completely] replaced with an engine from a truck that had been set on fire and also had bad cams and lifters. I suspect the owners of the truck where that engine came from might have burned...
  3. D
    Misfire Codes After Engine Swap
    I got a 2010 Dodge Ram at an Auction Last Year. A month into driving it the engine seized. I put in another engine that was swapped out because of a bad cam, is what I was told. I put in my old cam in after inspecting it. MDS lifers were still good so I put them in the "new" engine too. I had...
  4. O
    mds lifter missing pins, rod bent
    So, I know the pins don’t have to line up with the hole in the lifter, but has anyone had where they can’t see the pins at all? Just re-did the cam, lifters, etc… Fired it up and had a cyl 1 misfire. Turned out intake rod seriously bent up. Turned out brand new lifter for exhaust had no real...
