need help
  1. S
    Multiple Misfire 2009 Ram 1500 5.7 - Need Help
    Hi guys, new to posts and ram 5.7 truck in General. But basically my issue is the multiple misfire code I am getting, and it does not show me which cylinder is actually misfiring. I had got the truck for a fair price due to misfire on cylinder #5 and did all the basic tests and ended up needing...
  2. D
    2015 ram 3500 complete delete with trans tune
    In need of help im new to this forum but I can't quite find the help I need but I have a bone stock 2015 3500 6.7 with the 68 rfe I want to do a complete delete my truck has 90k miles on it and I know the tranny I have isnt the best so I'd like to get a tuner that I can use for my transmission...
  3. 2
    Engine Swap
    I currently have a 2001 Ram 2500 SLT Larime. Its original motor was 5.9L v8. Motor and transmission was no good so I swapped in my 5.9L v8 from my 99 ram 2500 base model. Same motor, trans, rearend just with no bells or whistles. I had to cut and splice the injector plugs from my 99 to my 01...
  4. Lifted_ram_18
    Blown diff
    Good morning all, so yesterday im driving along, feel a loud pop, then my truck is in like neutral, look under thinking i snapped the drive shaft but its still spinning, so i put it in 4wd lock, to get me off the road, starts going then goes back as in neutral, saying 4wd power reduce due to...
  5. Len80
    Need some help w Limited 1500 I just bought
    I just bought a Ram 1500 Limited w only 30 miles on it. The buying process was brutal and the truck didn’t get to the lot until late at night(was brought from their sister lot). The next day I realized my truck didnt have any floor mats in it. Also the bolts holding the seats in had a layer of...
jimn
