no crank
  1. R
    Fixing PCM communication error - no-crank & radio giving anti-theft code error
    Hi all, I am just posting this here as I have encountered this last week and finally found a resolution to this problem in my 2013 Ram 1500 with the 3.6L V6 engine (SLT). Last week, I came to get into my truck and I turned the key, and... * nothing * Keys were definitely being detected and I...
  2. Jademoon1981
    02 ram 4.7 4x4 no crank no start
    Has been running decent with only 1 code for an O2 sensor. Went to work came home and parked. Went to run to the store and no crank. Putting key in ignition with door open dings, dash, radio, head lights, done, heater fan all turn on. Turn key over and no crank at all. First thought maybe...
  3. 1
    2006 RAM 1500 Hemi won't crank after shutting it down
    The starter in my 2006 Ram 1500 Hemi wouldn't crank if I tried to start it shortly after shutting it down. However if It sat long enough, it cranked normally. Yesterday I found the bolt holding the negative battery cable to the engine was backed almost completely out. Not sure who left it...
  4. bugnutz
    Mystery Part!
    Troubleshooting NO CRANK, still again, whatever --- I had to have it towed home the last time I drove it and now having time to work on it. I found this mystery part dangling inside my console under the steering column. I was able to determine that the numbers there refer only to the...
  5. D
    2012 RAM 1500 No Start Electrical Issue?
    I have a 2012 Dodge Ram 1500 with the 4.7L 8 cylinder engine that seems to have some sort of electrical issue. When I turn the key to on or start the truck, there is no response from the car but if you wait there for a few minutes with the key in the ignition, power comes to the dash and will...
