02 ram 4.7 4x4 no crank no start
Jademoon1981
Illinois
Has been running decent with only 1 code for an O2 sensor. Went to work came home and parked. Went to run to the store and no crank. Putting key in ignition with door open dings, dash, radio, head lights, done, heater fan all turn on. Turn key over and no crank at all. First thought maybe starter tapped it a few good times nodda. Learned how to by pass the relay to see if it would start and didn't. Went ahead and put a new starter in, same thing no crank. Can hear the fuel pump kick on, switched relays with another to see if that was the issue and nothing changed. Looked to see if there was a home installed security Installed under steering column but nope. Wiggled all the wires under fuse box and made sure computer was connected good. Tried starting in neutral, nothing. Checked for new codes but of course aren't any.
Battery seems to be fine but it's currently 1 degree here and took forever going in and out of the sleet/snow to warm myself up to even get the starter on. No way to get to the auto store to test battery so going to try the meter on it tomorrow.
What would be your next step to try?
Kmiko
