no power
  1. A
    Bad win module vs bad rf hubs
    2016 ram 1500 express The truck one day shut off pulling out the gas station.. the key wouldn’t read to roll the windows down turn the radio on nothing not even the locks worked I was lucky that I knew a tow truck driver that hooked me up with a tow for a doobie, after hours and hours of...
  2. J
    Water damaged/Flooded, No power to most electronics
    Hey Y'all, This is my first time posting in a forum so apologies for any mistakes with posting. Anyway, I've recently got a hold of a (basically free) 2011 Ram 1500 4.7 from a close friend, and as the title says, it's a flood truck. It was fully submerged for about 8 hours in freshwater during...
  3. V
    2007 Ram 1500 Intermittent no electrical power
    Hi guys. New on the forum. My 2007 Ram 1500 has a weird intermittent problem. If I can use the remote to unlock the truck - no problem truck runs 100% fine. Come back an hour, day two days later when I try to unlock the truck with the remote nothing happens - bad day. When trying to start the...
  4. D
    2018 uconnect ra1? Won’t come on.
    Hey guys, I’ve been through everything I know to check at this point and I’m pulling my hair out. Okay so here’s the story. I bought the truck the radio worked fine, I had a heater core leak so I removed everything and replaced the core. After getting everything back together my radio screen...
  5. 9
    Truck Running rough
    Hi all, I’ve got a 99 ram 1500 5 speed 4wd that is running like crap. Idles rough, and will barely pull itself out of the drive way. The engine has new: cap,rotor,plugs, wires, coil, o2 sensors,injectors, cam sensor and crank sensor. I’ve tested and tried everything I know to test and replace...
  6. R
    Cranks and Runs but losing Power when gas is pressed
    I have a 1999 Dodge Ram 1500 4x4 with the 5.2 V8. I got the truck back in October of last year and had the transmission rebuilt shortly after getting it. For a 23 year old truck it has been running fine. A couple weeks ago I went to leave home and when I pressed the gas it wouldn’t go and was...
  7. D
    Engine screams, but truck stops moving, pulling uphill
    2002 Ram 3500 dually, 5.9L Cummins Turbo Diesel. Bought used, has had this problem since the beginning. When pulling a gooseneck trailer with roll-bales, if you start up much of a hill (even with a good run at it), the truck will eventually stop moving, while the engine just winds up and is...
  8. H
    2003 Dodge Ram 5.7 Red Lightning Bolt
    I have a 2003 Dodge Ram 1500 5.7 hemi. It will sporadically start idling funny and the red lightning bolt will pop up and I have absolutely no power, shut it off and restart and I will run fine until it does it again could be an hour or a week. I have taken to one mechanic who replaced the...
  9. H
    Won't start, key stuck, no lights/power
    I drove to a worksite today, about a 30min drive, in my 2015 Ram 1500 (V6) and briefly parked for about a minute. When I went to start my truck it died, didn't try to turn over or anything, now my key is stuck in the ignition and nothing has power not even lights/door chime. I connected a jump...
  10. J
    O2 sensors heaters upstream fuse location
    where is the o2 sensor fuse I can’t find it. 2012 ram 1500 5.7L
  11. P
    Dead Battery? Not so fast
    Hi everyone. First post so go easy on the flaming. I have a 2015 Ram 1500 Big Horn that seemingly had a bad battery. Everything was perfectly fine until yesterday. I was installing an OBD2 scanner in the port and connecting it to a tablet installed in the car. The OBD2 scanner was one of the...
  12. D
    2012 RAM 1500 No Start Electrical Issue?
    I have a 2012 Dodge Ram 1500 with the 4.7L 8 cylinder engine that seems to have some sort of electrical issue. When I turn the key to on or start the truck, there is no response from the car but if you wait there for a few minutes with the key in the ignition, power comes to the dash and will...
