Cranks and Runs but losing Power when gas is pressed
Raider11
Aiken, SC
I have a 1999 Dodge Ram 1500 4x4 with the 5.2 V8. I got the truck back in October of last year and had the transmission rebuilt shortly after getting it. For a 23 year old truck it has been running fine. A couple weeks ago I went to leave home and when I pressed the gas it wouldn’t go and was like it was struggling to get fuel. As I pressed the gas more it would rev the RPMs almost launch and then when I slowed down it would do it again. I got it back in the drive way and turned it off and cranked it right back up. I pressed the gas pedal and it sounded like it had a loupe to it while pressing the gas in park. After doing that for a little while and checking the spark in the plugs it seemed to be fine and running like normal again. On the way home a few weeks later it did it driving down the road. I have a video from inside the truck as well if that would help. Not as familiar with these trucks because I have always had Fords. The motor sounds fine and cranks but when you press the gas it’s like it’s struggling to get fuel and then when it does it shoots the RPMs way up. Any help or anyone else have a similar problem and know what the issue might be? Thanks in advance!!
Musky Mike
NC
Check fuel pressure, if that is good, I would suspect maybe a plugged catalytic converter .
Old Retired Guy
Fort White Florida
5.2 L
Is it setting P codes? If you dont have an OBD scanner box, you can click the ignition switch on 3 times in a row and read the P code that will appear in the odometer window. Look it up on the internet and maybe that gives you a clue. Be prepared to read and write quickly. Good Luck. Hope it has valid codes for you.
