oil leak
  1. J
    Oil next to ignition pack
    What is this called?
  2. S
    Massive Oil Leak
    My '01 Ram 2500 5.9L Cummins suddenly developed a massive oil leak. It drips constantly, to the tune of about a quart every 20 miles. There is oil all over everything below the front of the engine. (Possibly more oil on the passenger side, but that is guess work until I get it clean) I've...
  3. S
    Need Help with an Oil Leak on a 2018 Ram 3.6L!
    So, Santa this year gifted me an oil leak, Yeah!!! I have a 2018 Dodge Ram 1500 (gas), with a 3.6L v6. I have currently 118,000 miles and my last oil change was about 7500 miles ago. To my knowledge this is the first time I have discovered a leak on my truck. After I noticed the leak, I...
  4. T
    Need some help 5.9 Cummins Oil leak
    I've got an oil leak coming from below/Behind this part. The breather drain tube connects to this. it is above the computer on the driver's side. Does anyone have the parts diagram from here or know what needs to be done? I've got an oil leak (Probably) coming from under this
  5. A
    Oil leaking help
    Ok, so I don’t know much about fixing trucks but I just got a 1996 Dodge Ram 1500 5.9 and trying to learn. I have a major oil leak and trying to figure out we’re it’s all coming from. The oil pan is soaked of oil but it also looks like it’s coming from above so the oils pan may be fine. The oil...
  6. R
    Oil pressure sensor
    I’ve got a 2002 Ram 1500 3.7l v6 and I discovered a pretty bad oil leak under the truck. Was coming from the oil pressure sensor where the plastic goes to the metal nut. I changed it, all ok. 3 days later the same has happened so put it down to a faulty part so replaced it again. The same has...
  7. THRobinson
    Stalls and Running 'Oddly'
    Had this Ram about half a year now... and for the most part it's been fine, but lately been having a few quirks. Posted before about an issue... auto shift on the steering, sometimes won't pop into Park without a few attempts, and a few times flipped into 2nd while driving because between D and...
  8. A
    What is causing this oil leak.
    So i have a 2007 5.7 1500 with oil leaking someone near the top drivers side of my engine. It only leaks under pressure (never leaves a puddle) but leaks enough that i noticed a puddle on top of the engine itself and a lot has been running down to where the exhaust meets the engine and burning...
