park sensor
  1. T
    Parksense sensor issue
    I'm having an issue that I've searched high and low for, and can't seem to find anyone with the same or similar issue. My parking sensors work just fine during the day, but once my headlights come on once it gets dark, my Parksense stops working any time I reverse, or slow down below 5mph. I...
  2. Matthewk88
    Electrical issues and park sensors
    I just bought a 14 ram 3500 Laramie and found a couple issues with it. 1. The channel down and volume down buttons on the steering wheel do not work but all other buttons do. 2. If I turn the radio volume up to 22 or higher the audio skips and even cuts off but if I turn it back down to like 10...
  3. J
    Front Park Sense throws an error at 6-8 mph
    This started out as an intermittent issue. I'm getting a message and a ding every time I accelerate through 6-8 mph. The message advises that I should service the front park sensors. The system then disables the front sensors (light in the button comes on). When parked, the sensors work as they...
  4. J
    Park sensor failing on the front. How do I test? 2018 2500 SLT Diesel
    Every week or so I get a "ding" and a message saying that the front park sensor(s) are failing and the computer turns them off. I've wiggled the connectors on each of the 6 sensors and attempted to test each one but so far my tests are inconclusive. After the next engine start they seem to be...
  5. B
    Adding front park sensors / front camera
    Hello all, I searched around a bit but was unable to find a definitive answer, so here we go : Bought a 2019 Rebel for the wife. It had every option she wanted except for the park sensors. It does obviously have the backup camera which is great, that is enough for her when backing up. The front...
