I have a 2015 Ram 1500 that started with electrical issue I believe. At least 3 months ago when starting the truck I began having an issue where after the dash lights complete their "test", just about all of them would come on and stay on. It'***** and miss when I start it. Sometimes they the...
Truck threw a check engine light at me this morning and the code was indicative of an oil pressure issue. (Reading 99psi, super high, at the time)
O’reillys scanner suggested changing the oil pressure sensor.
“Cool, easy peasy” so I thought. Easy peasy on Hemi’s, frustrating enough to make me...
Hi all. I deleted my 2015 Ecodiesel at 150K miles and have 180K now. A couple of connectors I couldn't get to (rather get disconnected) during the delete and I just cut the wires. One I cut and the sheeth pulled off and left 4 wires exposed and hanging down and rested along the drive shaft...
I just got a 2016 Longhorn Eco Diesel with 176k miles. The other day on the way home on the interstate the CEL came on and the power went down struggling to get over 60 mphs. Once I got off the interstate it corrected a bit but still winding out at 3000 rpms and only shifting when I took my foot...
03 Dodge Ram 1500 w 4.7 engine 118,000 miles. I have a ticking noise coming from the left side of my intake manifold (verified w a stethoscope). Why would it be ticking? The truck has lost a significant amount of power and shakes a bit when I get up to about 50-55mph. This first started after a...
I’ve noticed a loss of power or the building thrust normally experienced. 2014 Ram 2500, 6.7 Cummins. 185K. To correct this I have changed both fuel filters as well as crank case ventilation cartridge. I have also replaced the lift pump in the tank. Experience a noticeable difference after fuel...
Question guys;
07 ram 1500 5.7
Slight loss of power at low rpm and/or low speed. Eventually comes back, sort of acts like a fuel system loss or decline momentarily. Rpms dip everytime. TIA
