power steps
  1. carid
    Upgrade Your Ride with AMP Research PowerSteps – $200 OFF
    Looking for the perfect running boards for your truck or SUV? We’ve got you covered with a range of options from AMP Research, designed to give you both style and convenience. The PowerStep Xtreme is built for tough conditions. It extends when you open your door and tucks away when you close it...
  2. justatruck
    Mopar Factory Power Steps
    Howdy, I have the factory power steps on my truck. I broke the driver's side step off the truck. The motor is still good (runs) but the hinges are broken. Can I just buy 2 Left Side Hinges (#7 in the Diagram below)? I am wondering if anyone knows if the power motor unbolts from the front hinge...
  3. David Tittle
    CONFIRMED: Amp Power steps for TRX
    Hi All, Wanted to let you know that I installed Amp Research Power Steps model number 76240-01A on my 21 TRX this weekend and they work perfectly. Install took 3 hours with a helper and the only real challenging part was getting wires through a rubber grommet in the firewall -- it's a tight...
  4. continuecrushing
    FS: Amp Power Steps With Plug and Play Harness 2016-2017
    Hey guys/gals, I've got my Amp power steps for sale, in great condition. These running boards came off my truck (2016 2500 crew cab) in place of actual rock sliders. These function MUCH better than what I put on the truck, and they will definitely be missed. This is the kit that includes the...
