problems engine
  1. G
    Engine noise, want ideas for more verification
    Ran into a new noise with my engine. Truck is already pulled apart down to cam and lifters I will upload pics next time I think of it. I am already aware of exhaust manifold fail that was a pre existing issues but this noise randomly devoloped on driver side, the exhaust manifold fail was on...
  2. Len80
    Problems with my new limited v6, anyone else?
    I but the bullet, reasearched, saved, and finally purchased a 2025 Limited a month ago. I’ve had it back to the Dealerships shop because in low parking lot speeds it feels jumpy like the trans is slipping. Also, i feel a lag, unlike the youtube videos I’ve seen raving about the power of the High...
  3. J
    ‘21 5.7 E-Torque shuts off while driving
    I was Going about 5mph around a roundabout when the truck locked up the rear tires, completely stopped, completely shut off and applied the electronic E-brake. I started it back up and ran perfect all the way home. Has this happened to anyone before? Thinking it has to do with the E-Torque...
  4. W
    P0303 code
    Alright. About a month ago my 1998 ram 1500 popped up with a p0303 code. I got this code a couple years ago, cleared it and it never came back until a month ago. At first I thought it would be on the ignition side of things. Replaced spark plugs, wires, distributer cap, rotor and coil wire. They...
  5. D
    Unexplained Engine Problems (P0300, Unexplained Coolant Loss and Cruise Control Not Activating
    I have a 2005 dodge ram 1500 slt quad cab 4.7 Engine non-flex For the past 2 months, I have been having a p0300 misfire code (random intermitted misfire) and sometimes it will throw in a p0307 (cylinder 7 misfire) code. I have replaced my spark plugs in all my cylinders and replaced the...
  6. N
    91 318 Starts and dies immediately
    Hey all, I Have been restoring this 1991 Dodge W150 with the 318 and 4-speed auto. When I bought it, it had been sitting for about 9 months but it ran and drove just fine for about 20 miles. Then one day I went to start it and it fired but then dies immediately. I have since determined that...
  7. N
    HELP!!!!
    Hi, my ram15002013 5.7 hemi dont want a run . He start but dont run, i check de fuse all ok , pressure of gaz is 64~psi each spark plug make fire, i change the position craink sensor but he dont run any more please help me. thx
Reticle918
