#rebuild
  1. M
    Rebuilding off a Block what all do i need?
    So pretty much buying a 360 Magnum block, it will be bored/honed/hot tank cleaned and come with -new cam bearings -new freeze plugs -stock pistons -stock pistons -timing cover -harmonic balancer/lower pulley My question is what else do I need to get it as a fully function engine and what would...
  2. N
    46RE rebuild two steels for top hat?
    I have a 46RE out of a 2000 Ram1500 4WD that I am rebuilding. My rebuild kit comes with extra clutches and steels so that I could rebuild the clutch packs with an extra clutch each. Only problem, the kit does not come with new machined top hats for this purpose (or any new top hats for that...
