shift indicator
  1. RonG
    48RE Shift Issues
    For quite a long time, my 2005 Ram 3500 (Cummins diesel, rear wheel drive, SLT) had been very difficult to get out of Park. I studied "YouTube University", as well as some of the online Forums and decided to put in the "Detent repair kit" from TransGo to correct the issue. What should have...
  2. R
    Transmission/shifting issue - going out of gear
    I recently purchased a used 2019 Ram Rebel and have had a few odd occurrences with the transmission. Today while driving up to a red light, right as the truck was going about 5mph, the dashboard showed a message "Shift to P then desired gear" and the D letter started flashing. As I was stopped...
  3. J
    Shifter stuck in park, dash indicates reverse pls help
    My dad and I replaced a faulty clock springing a 2011 ram 1500 slt 5.7, after putting everything back together, the truck wouldn't start and the gear indicator on the dash says the truck is in reverse. I tried the shifter override and it didnt help
  4. H
    2001 Ram 1500 Shift Indicator Steering Column Bracket
    I am looking for the bracket that mounts on the steering column for securing the gearshift indicator cable. For the first image, I believe I need the black bracket on the left side of the cable with the thumb screw. The second picture is from the actual truck. Does anyone happen to have...
Sunmerk
