shift solenoid
  1. A
    transmission solenoid
    I need help with my truck RAM 2014 3500 6.7, a while ago we started to have issues with the truck going to limp mode , after checking codes i reilase that it was a miscommunication from the TCM after looking for the issue i found out that the wiring harness on the driver side had a repair made...
  2. B
    Would a 2003 3.7L Valve body work with a 2007 5.7 Hemi?
    I am trying to replace my step-moms valve body/shift solenoid in her truck and was able to get one that belongs to a 2003 3.7L ram 1500. I have been trying to search it up and from what I can see they use the same transmission and can work even if they are 2WD to 4WD, all you have to do is...
  3. R
    2011 2500 won’t shift out of park. At a loss.
    Hi. New here. Been scouring the forums for a solution to my exact problem To no avail. the truck is a 2011 ram 2500 diesel with a column shifter. The shift lever solenoid will not release on its own when I step on the brake pedal. the only way I can shift it out of park is if I use the...
  4. W
    Shifting issue. 1995 Dodge Ram 1500 318 CID 4wd automatic.
    I have a 1994 Dodge Ram 1500. It shifts ok then after a bit of driving, usually at 45mph it won't ****. Or it shifts hard. I have taken the cable soff the battery and connected them. Leaving them off for an hour then reconnecting them to the battery. I'm being told that on that year, there is no...
