shifting issues
  1. R
    2005 Ram 2500 Hemi 5.7 Goes to neutral at low speed
    I am having a issue with my Ram 2500 4x4 where when accelerating from a rolling stop the trucks trans seams to slip like in neutral. I come to rolling stop and then hit gas. The truck goes through 1st gear then when it should go to 2nd it slips. If I step on gas more nothing happens. If I...
  2. W
    Shifting issue. 1995 Dodge Ram 1500 318 CID 4wd automatic.
    I have a 1994 Dodge Ram 1500. It shifts ok then after a bit of driving, usually at 45mph it won't ****. Or it shifts hard. I have taken the cable soff the battery and connected them. Leaving them off for an hour then reconnecting them to the battery. I'm being told that on that year, there is no...
  3. 1
    2013 Ram 1500 Longhorn Reverse to Drive Stalling when cold
    Hi Guys, I’ve resorted to the Forum after spending thousands of dollars and hundreds of hours attempting to research this exact issue. I’ll spell out what I’ve done to date for fixes in the shop and personally then I’d love to hear all thoughts and inputs ; greatly appreciate everyone taking...
  4. D
    What is this tube?
    I recently bought a 2017 RAM 3500 with the 6.7l cummins and this tube is leaking. What is it so I can get it replaced. Also, since it started to leak, the truck shifts poorly.
Raadz
