sway bar
  1. alnbobby
    Do I Need a Rear Sway Bar?
    On my previous truck (2017 RAM 2500 HD, short bed), I installed a Hellwig sway bar to improve rideability when using my 2,800 lb truck camper. I recently purchased a 2022 RAM 3500 short bed that has an air suspension system with no rear sway bar. I'm hoping to hear some feedback on whether I...
  2. Ravi Dass
    Sway Bars rusted off
    Hey All, I was informed (by Dodge) that my sway bar links have rusted off therefore they are not covered by MOPAR lifetime warranty. Any recommendations for sway bars for a 2013 RAM 1500 Sport. Has about 245k miles so Im thinking I just replace the front and rear. Anything else that should be...
  3. LoneWolf3574
    Sway Bar Bushing Retainer Bolts
    I'm preparing to replace the steering gear, tie rod ends, sway bar links, and bushings on my truck (182k miles on them). While reading the FSM, I came across the directions where it says to discard the mounting bolts for the sway bar (stabilizer bar). Does anybody know why these bolts need to...
  4. P
    Sway bar end links keep snapping in half
    I have a 2007 Dodge Ram 1500 hemi 5.7 4x4 Any thoughts on why this is? This is the second time in 3 years that I’ve had to replace them. I buy from rock auto and they’re a perfect fit and are torqued to the spec in the manual. I’m lost as to what it can be. Any help is appreciated thanks guys!
  5. Waterfowler41
    FS: Roadmaster Rear Sway Bar 1129-135
    Part: Roadmaster Rear Sway Bar Part# 1129-135 What's included: Sway bar, new brackets/bushing, and solid end links. New hardware is included but the OEM bolts for the sway bar brackets and top mount of the link link can be reused. Price: $275+shipping from Chicagoland (Retail is $415)...
  6. NorZeman
    Sway bar upgrade
    All, I'm considering doing a Hellwig rear sway bar. Just curious what peoples experiences have been while towing with these upgraded bars? Any added lateral stability while towing? Any concerns about it? Too stiff taking weight off the inside wheel on turns causing spins/jackknifes? Other...
  7. Zachery Vrbas
    Which brand for front sway bar end links?
    Need help in finding front sway bar end links for my 2WD 2012 1500 that won't **** out in 4 months. Basically asking for a brand.
