towing capacity
  1. B
    Towing/no power
    I have a 2009 1500 with the 4.7. According to what I've read, I should be able to tow about 8000 lb "if properly equipped". I have the tow/haul button, so I assumed I was "properly equipped." The problem is when towing my camper (~3000 lbs), the truck has no power going up hills. On some of...
  2. J
    5.7 E torque towing capacity 12,750 when properly equipped*; what does that mean?
    Hey Guys I have a 2022 Big Horn hemi 5.7 etorque 5’7” bed that has a towing capacity of 8,110. I realize that the 12,750 towing capability is only available when the truck is properly equipped. Is there a certain gear ratio, suspension or other equipment that the 1500 needs to be fitted with to...
  3. A
    2023 5.7L V8 HEMI MDS VVT eTorque Engine 3.21 Rear Axle Ratio
    Hey ya'll this is my first post and super happy to have found the community. Bought a 2023 RAM (engine specs in title) and towed my new 2022 Grand Design MK200 travel trailer from TX to GA about ~1,000 miles. I've read some of the posts here and I've found what you guys have said to be extremely...
  4. I
    2019 Ram 1500 Classic Warlock Towing Capacity
    I just bought a 2019 Ram Warlock with the 3.6L Pentastar 4x4, and it has 3.21 gears. I truly can not find the answer I am looking for online. It says I have a Max. Trailer Weight Rating 4,440. Is this the total weight of both the trailer and the vehicle on the trailer?
  5. K
    Towing specs?
    Recently I bought a 2019 warlock with 37k miles. Out of curiosity I crawled under and to my surprise I saw coil springs instead of leaf springs. Are there heavier duty springs out there? Or is there any way to up the towing capacity a lil more? A quick google search says towing spec is 7,600...
  6. S
    Air Bags in Rear?
    Just wondering if anyone has installed air bags in the rear for towing in a 2020 PR. If so would it allow you to tow higher loads? Keeping in mind you would deflate them when not towing.
  7. Oilfieldman
    2020 ram 2500 tradesman trailer tpms came with the truck
    We just bought the truck new last night and I noticed it has 4 trailer tpms sensors in a bag with the owner’s manual and also a little flat piece of plastic with 2 plug in connectors on it. It has the 5th wheel prep pack on it. Has anybody actually got this system to work yet? I’ve seen a bunch...
  8. E
    1500 V6 Towing Question
    Hello....Newbie here! I have a 2019 1500 V6 with 3:55 ratio. My tow capacity is 7490 and my GCWR is 12,900.....dealership advised that it is actually 13,900 but manufacturers always give a 1,000lbs buffer???? Here’s my situation/question: I recently bought a travel trailer that weighs 6100. I...
  9. D
    Lifted, Towing Capacity, and Gear Ratio
    I’ve got a 2019 Ram 1500 Classic 4x4 Crew Cab Hemi 5.7 8-speed with 3.21 axle. The tuck has a 4” lift kit from Mopar and 35” tires. I got it new this year and had no plans on towing, but now we are getting a trailer in the next couple of weeks and I’m concerned about the towing capacity of my...
  10. ErnieD
    2019 Ram 1500 Classic; 5.7 Hemi; 3.21 gears, 6900# GVWR Towing Question
    Ok, I need some real world results. Please don’t post specs as I’ve researched the numbers over and over on what the RAM engineers have stated this trucks ratings are. Also I am a master certified truck tech, so I don’t need a lesson in horsepower or gear ratios. Below is my question : Specific...
  11. K
    Axle ratios limit towing?
    Some of you owners please post factual data about the different axle ratios and the towing limits please. (No speculation please, actual facts) I read in another thread that wasn't about towing, some tangent about the 3.21 can only tow 7,000 or 8,000. ??? The 3.92 can tow 11-12,000. Is the...
  12. M
    2019 1500 5.7/eTorque w/3.92
    My payload is listed at 1830 lbs. and my towing ability at 11,230lbs. I'm looking at <10K lbs 5th wheels but would like to get the biggest I can safely tow. I know not to exceed the tow weight. Will aftermarket airbags (Timber, Airlift, etc.) make a big difference in the ride and safety? We...
  13. J
    Confused about Towing Capacity 2016 V8 Quad Cab
    Forgive me if this has been asked before. I searched but did not see it. I have a 2016 4x4 V8 Quad. I have a 31' tow behind dry weight 5700lbs. The 2016 RAM 1500 Trailer Towing Chart - SAE J2807 Compliant guide says my tow max is 8710lbs. However I noticed on my bumper it says the following...
  14. M
    Airlift airbags up the tow rating?
    2007 QC LB 4x4 tow rating is 8300 max. I’m looking at campers with bunk beds and most are almost 6k or over. So whats everyone’s thoughts on the subject if I’m adding airlift air bags for towing help? Thanks in advance.
  15. AustinAggie
    Any 1500s upgrade from ~4500 lb travel trailer to 5500 lb or 6500 lb?
    I drive a 2016 1500 Hemi CC SB with 3.92 rear axle (10,300 max tow rating). I currently tow a 4500 lb Jayco travel trailer (26.5' box, almost 30' total - one of the common bunkhouse models with no slideouts). I use a Reese WDH with anti-sway bars.. all without much trouble. It's noticeable...
