transmission fluid change
  1. K
    2019 Ram 1500 transmission fluid change?
    I recently purchased a 2019 Ram 1500 Lonestar crew cab 4WD and 5.7 Hemi V8. It has 122k miles and the previous owner had it in Texas for 4 years, then moved to NM then to Indiana where I purchased it. The Maintenance records are very thorough, and it has no current issues. However I’m concerned...
  2. C
    Transmission service
    Greetings, all… I recently purchased a 2015, 1500 tradesman with the 3.6 and the 845RE transmission with 94k miles I am seriously considering getting the PPE pan, but want to ask about fluid. It would appear that the Valvoline max life oil that many seem to use is not available in California ...
  3. H
    Transmission fluid and rear differential fluid change
    So my 2014 Ram 1500 SLT 5.7 Hemi has 195k miles and I am deciding to change the transmission fluid and differential fluid as well since I am not sure how long since they've been changed. I've never done either change before so I am asking for advice as well as what are the correct type of fluids...
