troubleshooting electrical
  1. B
    Infamous steering wheel control issue has me stumped
    Truck 2015 Ram 1500 tradesman. Motor swap performed before I bought it donor motor was a 2017. Ivr had the truck 2.5 years and steering wheel controls have never worked. Guy I bought it from said they worked before the swap, but I dont know if I trust him. Cruise control and gear selection...
  2. J
    Bench seat wire harness
    I am trying to find a harness to tap in to for floor lights on my 2018. I found this wire harness under the flooring under the bench seat in the rear on the passenger side. I check for power but there's no power going to it. Does anybody know what this connector is for and where I could find a...
  3. B
    No voltage to Rear window Defroster
    I recently noticed that the rear window defroster in my 2016 Ram 2500 Laramie was not working. While troubleshooting I found that the drivers side button had come off the window and the wire was just floating there. I attempted to solder the button back on, but was unsuccessful. I ended up going...
  4. 1
    2017 5.7 won't crank intermittently.
    For the last 3 months I have had intermittent problems with my truck not cranking. It won't crank with the remote or the push button. When I try and start it I can hear a click but the starter doesn't engage and crank the engine. I can sit in the truck for about 5-10 minutes and I will hear...
  5. raidbossreid
    Fast Blinker and Beeping ONLY while headlights are on
    I have a 2002 1500 V6. It has recently started fast blinker and beeping only when the headlights are on. During the day when I don't use headlights, no issues. At night while headlights are on, both blinkers and hazard lights trigger fast blinking and beeping noise. Any ideas where to start?
  6. B
    2013 1500 5.7 Lukewarm heat on driver side, hot on passenger
    Little to no heat and pressure on driver side, full heat and pressure on passenger side. When turned to AC, both driver and passenger have full AC and pressure. -Replaced thermostat with a 203 temp -Temp going into heater core 195 -Temp coming out heater core 189 -Drain and filled the coolant...
  7. Attaboyslim
    Transmission repair turns dark
    Hey guys and gals ... am new to the forum so if I make a mistake, please correct me ... I may be a rookie but I learn quickly. So, a 1997 Dodge Ram 2500 van with a transmission (torque converter) problem has been corrected but somehow this process caused a blackout. Specifically, the dashboard...
