wiring diagram
  1. S
    Drivers front window not working all the time.
    Needing some help. My 2014 3500 drivers front window only works for about 8-10 times and stops until I pull connector 3 from the door module (power,ground, and I believe can) and immediately connect it back to door module and it will work again for about the same amount of time. New switch and...
  2. A
    Iat issues???
    I have a dodge ram 2004 5.7l v8. P0113 and check gauges and engine light come sometimes. Not often, but more in cold weather. The car feels jumpy and slow sometimes and backfire when I start it sometimes and I have change the iat sensor, but it didn’t work. runs unevenly at idle and sometimes...
  3. bassmatt
    2019 ram 3500 hemi backup cam inop - need help
    Hey all I have an inop backup cam with a break between connectors XY545A and XY543A. Diagnosed by ram dealer. This is a base model with the small screen, not the 9". Problem for me is I can't locate that myself by tracing the line, and the only diagram I've found so far doesn't have the...
  4. d_giessel
    Fuel pump voltage and diagrams for 2016 6.4L
    I'm looking for technical info on the fuel pump. I'd like to see a wiring diagram, and I'd like to know how much voltage (and from which port) I should be getting to the fuel pump. I am diagnosing the crank-but-no-start issue on my truck. (2016 6.4L) Up to this point, I have a new battery, new...
  5. T
    Wiring Aux Backup Lights to Reverse/Upfitter
    I've been searching for days on how I would wire up my BD S2 backup lights to both my reverse lights and also an upfitter. The outcome im looking for is to have the extra lights come on when I shift into reverse as well as by themselves while in park with the press of one of the stock upfitter...
  6. N
    2019 Ram 1500 Classic Wiring Diagram Request
    Hello everyone, I am looking for a wiring diagram for my 2019 Ram 1500 Classic 3.6L V6 Tradesman 4x2 since I want to replace my manual windows with powered windows. The Ram Body Builder's guide doesn't have any schematics and I would prefer to not spend $100 for a USB...
  7. Z
    1984 D150 Brake Lights not working
    New to these 1st gens so sorry in advance. Got a 84 d150 318 727 marksman with no working brake lights. Brake switch has been checked and is getting power out when pedal is depressed. Can send power to them with a power probe through the bulkhead connector using the yellow/black wire and they...
  8. E
    5 cables with same color pcm help indentifying
    i cutted the c3 to solder a better one but didnt notice that there were 2 16awg and 3 20 awg with the same color and now i dont now which cable is which i can identify from the pcm with the pin order but no in the harness do they have a number writen on them or i have to trace back each cable?
  9. B
    Manual to power/heated conversion
    I've got a 95 2500 5.9L V8 that currently has the metal frame tow mirrors on the door. I'm wanting to install the new gen flip-up tow mirrors with power and heat. I've got the power switch and the mirrors to install. What else will I need to make them work? What's the likelihood that the factory...
  10. R
    2002 Ram 1500 obdc connector
    I accidentally kicked my data port and it fell apart so I'm trying to find out the wiring for the port. I've not found anything so far by google searching so I'm asking here if anyone has a wiring diagram for thte dataport on a 2002 Ram 1500 4.7L 4x4 with these wire colors pink/blue pink pink...
  11. Sean A Parker
    Need to know Wiring
    Hey guys, Just got a 2014 Ram 2500 5.7 Hemi 4x4 to tow the family 32ft camper. It is lifted so i would like to install a wireless backup camera. Hope someone can help me out. I'm limited on my mobility due to military service injuries, so I was hoping someone already knew what wire is...
  12. P
    Stereo wiring diagram
    Hi! Im looking for the whole wiring diagram for the stereo with navigation on my Ram truck from 2012. I search the internet but can find nothing which is really weird. Im specially looking for the wires for reverse and (if there is any) for parking brake. Thanks.
