Bugpete
Federal Way, WA
5.9L V8 360
I've got a 95 2500 5.9L V8 that currently has the metal frame tow mirrors on the door. I'm wanting to install the new gen flip-up tow mirrors with power and heat. I've got the power switch and the mirrors to install. What else will I need to make them work? What's the likelihood that the factory has the wiring in the door already? Where would I find the necessary wiring harness to make things all work if it's not already installed?
Fast69Mopar
What is the factory trim level of your truck? It unlikely that the factory wiring is in the door for power/heater mirrors. It would be very easy to make your own harness on the ground and then install it into the doors and connect the mirrors.
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
