‘18 bilstien level part #
M4-AR
WA
Can’t find any part numbers specific to my ‘18, wanted to make sure it’s the same as the ‘17 before I order parts.
(Front and rear 5100’s)
Also is it recommended or necessary to swap the UCA’s for a 2.1” level?
Ricks Ram
I would think the shocks should the same. Bilstein doesn't update there catalog very often. As far as the UCA'S go
the 5100 shocks don't let your control arms travel past there factory parameters. You don't need to change them but some people still do just for the extra insurance and also a upgraded control arm. Many many people are running the Bilstein shocks with no issues. I had mine set at 2.1 for two or three years before I finally installed my 6" lift with stock UCA'S with zero issues.
Sent from my SCH-I545 using Tapatalk
M4-AR
M4-AR
WA
Thanks, I figured they were good, but wanted to see if anyone ran into issues before I pulled the trigger.
