01 ram 1500 2wd lift help
mattjg260
5.2 v8
Hey guys I have a 2001 dodge ram 1500 2wd with 3" coil spacers in front and 2" blocks in rear I have thought about putting on a 2 " add a leaf and a 3" block instead of the 2 that I have on (i would like to keep what I have on their but seems like I have to make a sacrifice. For the front I planned on adding a 3 inch spindle lift I have 285/70/17 tires on it now and my biggest set back right now is finding shocks for what I'm planning (i dont whant to spend a fortune, would like to keep it under $650ish. please let me know your guys thoughts/opinions on this thank you
Merc225hp
NA
truck
gas
Using spindle lift does not mean u need longer front shocks ones u have on there now will be fine as nothing will change as u ar just dropping the spindle. As for the rear going up one inch should also not be a problem either.
Sooo??
BBartow
New Port Richey, Florida
5.9L Magnum
Sooo??
He's taking the 2" blocks off and adding a 2" AAL + 3" blocks.
Merc225hp
NA
truck
gas
K thanks, so rear will be 3" over stock.
SSGart
