tswannnlk
I got some Bilstein 5100's for my 4th gen 1500 a while ago. I set them to the 2.8 setting to get the max amount of lift. However, the front end is still about an inch to an inch and a half lower than the front. If possible, I'd like to have the front and the rear completely equal. I do not tow or have much weight in the bed most of the time. I'm still running the stock upper control arms because I have not noticed that they have any form of extreme angle due to being on the 2.8 inch setting. If I were to get new upper control arms, would they provide any more amount of lift to the front end of my truck or are they solely for correcting the geometry between the upper control arm and the ball joint? It would be nice to know if there was even one that isn't exactly intended to provide more lift but it does because of the different design intended to correct the front end geometry. Thanks!
