19Slick69
- Jul 13, 2019
- 29
- 9
- Location
- Illinois
- 2002 2500HD
- 5.9l gas
So the question here, I found the blue trailer brake harness connector(terminal) under the dash. It is firmly connected or mounted to (what I believe) the main wiring harness (plastic) block left side of steering column. This particular terminal/connector is rectangular in shape and blue in color. The problem is that it's firmly attached to the body of the main harness. As it stands, there's no room to plug another connector into this terminal without removing the blue terminal (connector) from the main wiring module body. Is there a way to free this terminal allowing it to detach from the main wiring harness body. Is there a method to release it from this harness body, it looks as though it is capable of being detached....but I need help... before I break something. Thanks for any help offered!!
