Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
have you scanned it any codes? When was last time spark plugs where done? You should also get a fuel pressure guage check the pressure when running ect.
Dealing with that rt now compression test fast and easy first, i threw parts plugs can trigger crank trigger smoke test etc.. do the simple cheap compression test rt off, mine this time valse spring snapped same description as yours dead on.. before that valve seat drop,
