03 2500 charging issue
Bobskow
I have a 03 3500 Dodge Ram I've changed the alternator I've had my battery checked it's okay showing 12 volts. When I start engine it charges for a few minutes then the volt gauge drops to nothing. Vehicle will run for 5 minutes then the truck shuts down. I've checked all connection can't figure out why it won't charge
MikeT
Chino Valley, AZ
CTD
Check all connections involved with the charging system. Look for loose/corroded connections and grounds. Also take a voltage reading of the battery right after the engine dies - be interesting to see what the battery reads at that point in time.
Mike
B
Bobskow
Ok upon further investigation it seems the ECM tells the alternator when to charge how do I find out if the ECM is doing what it's supposed to? And if it isn't what is the fix do I have to go to a dealer ?
