03 Hemi Swapped to 04 Hemi Need 58psi Fuel.
Ramzman53
Flawda
Have a 2003 hemi with no engine swapped in a 2004 with the ecm and now i need 58psi fuel. Cant swap a 04+ fuel bucket because they are different designs, any ideas? Should i just add an inline regulator? or are there any other oem type of way to do it, thanks.
HemiLonestar
Navy Badge Coast Guard
MD
Swap the pump itself into the 03 hat. This has been done many times over. Should have gone with the 2005 PCM though.
R
Ramzman53
Flawda
04 was the only i could find in time unfortunately. To be sure is it the whole in-tank 2004+ pump assembly itself? Thought the silver part on top the 03 hat was the filter/regulator, wouldnt it still regulate it to 48psi? Attached 2 pictures, the one with the red circle is the 03 regulator. What would i be swapping over?
BGW656
